Aug 4, 2006 #1 Q Quigs Trained monkey Joined Aug 3, 2004 Messages 106 I just made a MBC but I'm not quite sure what vac. lines to hook it up to. Thanks Phil
Aug 4, 2006 #2 4 441120 4 Sale Joined Apr 18, 2005 Messages 1,294 Huh MBC.... manual boost controller?
Aug 4, 2006 #3 Q Quigs Trained monkey Joined Aug 3, 2004 Messages 106 yes, MBC = manual boost controller
Aug 4, 2006 #4 4 441120 4 Sale Joined Apr 18, 2005 Messages 1,294 If it is a spring and check ball set up, spring end goes to the wastegate port and ball end goes to nipple on compressor housing. HTH
Aug 5, 2006 #5 Q Quigs Trained monkey Joined Aug 3, 2004 Messages 106 Thank you I first tried also connectting the wastegate selonoid with the rest of it and that didn't bleed of any boost. If I hit WTO it would have pulled over 20psi for sure. But now its good
Aug 5, 2006 #6 4 441120 4 Sale Joined Apr 18, 2005 Messages 1,294 Yea, my wastegate solenoid just holds the harness connector in place now :biggrin:
