With a stock shorthblock i went 10.20's@133+ at 3:1 pressure ratio. 212/212 with less than .500 lift at the valve and good iron heads. I used a .040 compressed gasket to raise compression ratio to about 8.3:1. Ideally it would have needed 9.5:1CR and 3.3:1 PR to get the most out of it at sea level and run what i posted above. I was at 1100". Its doubtful you will be able to run it that hard on 93 alky.here is my build bison . strocked 109 k1 rods girdled champion heads 212-212 roller 60 pound inj front mount intercooler alky control dual nozzel ptc converter . thanks guys
No. You wont find many guys dipping in to the 9's or even making enough power to do so these days. They dont have enough engine and if they do they dont have enough sac to do so. A few hardcore but thats about it. Its an outdated compressor design and its not a good one if you are only looking for mid to high 10's. The updates im doing will be used on engines that will be making 9 sec power.ya i was told that turbo has gone 9s by a good friend . i asked jack at coottons and he told me mid to high 10s . has there been alot of guys able to dip into the 9s ?
You will need 30-32psi in good air with your engine to run high 9's. I agree with 28psi and running 10.30's if the tune and rest of the combo is sound. I run ptc 9.5" converters which help a lot. I had really good heads on that 9.3:1 engine with less then 26psi and i ran more duration at .050 . Ive recently gone faster with them on a different engine and different turbo but im not posting about it on here. With iron heads it takes more boost to get that mph with a 212 camrunsorry should open my eyes a little more. under 26 pounds ok i thought maybe i would need at least 28 pounds to maybe run low to mid 10s . thanks again for your help
You need to have a lot of disposable income to be able to run 9'si have a friend with a 67 chevelle that runs 9s talks smack alot about me and my friends buicks i would love to kick the sh#*t out of him on the track sounds like i need to upgrade some things on my car
JP112_89 said:Last I check there was 2 different T66. The 6665 (P-trim) and the 6668 in the older 60's Tnetics 60 series.
T-66(65) has the smaller exhaust housing similar to the .63 Garrett. T-66(68) comes with the bigger exhaust wheel and bigger exhaust housing.
Turbows6 went 10.3 @ 128.xx with T-6665 in his TTA. From what I have read, the Bigger 66 has went 10.2 @ 134 is pretty much maxxed.
The 66 compressor wheel becomes the issue when shooting for 9's. The billet 67 comp wheel is lighter, spools faster and can make more power on the right engine.
I have the T-6665 an I am extremely happy with it and am not taking it off anytime soon . Spools GREAT and doesn't need a lot of converter to spool due to the smaller exhaust housing.
But my goals are not 9's.
Joe
Black Air said:Bison running the PTC converter in your opinion is how much better than a Art Carr 9' converter?
There are more variations than that. Any 3 bolt ex housing could be found on any of them and some have the old garrett GT design large ex wheel that uses some different parts internally. Really old ones had a 76p ex wheel. There is 2 different compressor covers also. The
Smaller one will limit the potential of the compressor. With heads cam and Intercoolet low 10 sec power isnt too hard to get.
