1dollardog
Are we there yet?
- Jan 5, 2007
What could be done to a 2001 Regal GS in parts and labor to gain the most hp if the budget is set at 2000.00? How much hp can be gained?
What kind of HP and torque improvements should I see with the stage 5 set up?
save your money and switch the L67 to turbo that is what i am planning on doing i figure around 8,000 should do it nice!! dont forget suspension tranny,bigger brakes so 8-10 car will be flying!!
I dynoed around 255 HP and 270Tq to the wheels. Similare set-up except I had a cam instead of rocker arms and my heads where port/polished with bigger valves. You should see around 220-230hp and 240-250 tq to the wheels. I would do cam instead of rockers since a cam would increase duration and lift. Also need to upgrade springs if your going to run it to 6K rpms. Stock srings tend to break pretty easy at higher rpm's. With nos and un-tuned I dynoed 338 and 339 hp/tq. Trust me, if you want to run fast and not spend waayyyyyy too much money, do simple mods and run nitrous. If I had to do it all over again here is my mods for a mid 12 sec car.
Engine:
Cam, CAI, headers, heads (p&p with bigger valves), test pipe, free flowing exhuast, 3.25" pulley, 160 drilled t-stat, DHP pcm, Hoosier QTP's (drag slicks) and ZEX nitrous kit with a 90 shot. With a good tune you should be at 12.6-12.8 easly.
I was running faster than other who had water-to-air intercoolers, bigger cams, lighter cars and more mods. Keep it simple.
to satisfy my own curiosity, i found these prices.
zex nitrous $680
slicks $310
rims $200?
3.4" pulley $50
pulley installation tool rental $30
belt $24
dhp pcm $100.
180° thermostat $9
plugs 1 or 2 steps colder $30
downpipe with u-bend delete for $90.
that should put you near 300 whp - low 13, maybe high 12 for ~ $1500 before s&h and taxes. figure 6-8 hrs labour for everything.
cam is $300 ~20-30 hp (plus roller lifters ~$160), and tog headers are $350, and are worth around 20-30 hp.
ported heads can run $1200 for 'stage 1' setups... up to $2000 for full ported jobs. cai is worth ~4 hp. cat back ~7 hp. don't need 'em!
a cartuning kit starts at $3099, and is good for 296 whp, 438 wtq with just bolt ons. Cartuning Performance. this can easily be upgraded to 500+ whp for not much more.
the trannys are weak peroid...if your gonna get hardcore i would recommend a built tranny by either zzp.
