OK, this was supposed to be an enjoyable day working on my car. Turning into a nightmare. I'm trying to get the digital cluster out of the car. Now that I've given the speedo cable some slack and removed the screws, I've got the cluster pulled out as far as it will go.
1. How in the helk does one remove the wiring connector from the back of the cluster? Is there a release I can't see or something? I'm not talking about the VSS wires nor the ground strap - I'm talking about the approximately 12 pin connector that is attached to the rear of the cluster.
2. How in the helk do you remove the knob from the trip odometer reset? I tried turning it counter-clockwise as described on GNTTYPE, and all that did was break the switch.
Anybody who can give a quick answer (and who's done this before) appreciated...
Thanks,
Thanks,
