hey guys,
i need to unload this laptop because i got into some photography and lenses aren't cheap.
mint condition and includes a docking station with dvd rom/cdrw.
this cost me over $2000 and uses really good components. the lcd screen is a samsung and sells new for $400. i'm asking $400 shipped for buick guys. i have it posted elsewhere for much more.
this has usb 2 so you can run powerlogger. the dock as a serial port for older scan tools.
battery still holds charge. at least 3 hours.
specs and pics below.
thanks all
Part number: 23718LU
General
System Type
Notebook
Built-in Devices
Speaker, Wireless LAN antenna
Embedded Security
Trusted Platform Module (TPM) Security Chip Width 10.6 in Depth 9.3 in Height 1.1 in Weight 3.1 lbs
Color
Black
Localization
English / Canada, United States Notebook type
Ultraportable (Under 4 lbs.)
Wireless capabilities 802.11g, Bluetooth, 802.11b
Processor
Processor
Intel Pentium M 1.2 GHz
Core voltage technology Low-Voltage (LV)
Data bus speed 400 MHz
Processor features Enhanced SpeedStep technology
Chipset type Intel 855GME
Cache Memory
Type L2 cache
Cache size 1 MB
RAM
Installed Size
512 MB / 1.53 GB (max)
Technology
DDR SDRAM - 333 MHz
Memory specification compliance PC2700
RAM form factor SO DIMM 200-pin
Environmental Parameters
Environmental & energy standards compliance EPA Energy Star Min Operating Temperature 41 °F Max Operating Temperature 95 °F Humidity Range Operating 8 - 90% Sound Emission 41 dB
Storage Controller
Storage controller type IDE
Storage
Floppy Drive None
Hard Drive
40 GB - 4200 rpm
Storage Removable None Hard drive type Portable
Card Reader
Card reader type Card reader Supported flash memory cards SD Memory Card
Display
Display Type 12.1 in TFT active matrix Max Resolution 1024 x 768 ( XGA ) Widescreen Display No Color Support 24-bit (16.7 million colors)
Video
Graphics Processor / Vendor Intel Extreme Graphics 2 Video Memory Shared video memory (UMA)
Audio
Audio output type Sound card Audio codec AD1981B Audio output compliant standards DirectSound3D, Sound Blaster Audio Input Microphone
Input Device(s)
Input device type Keyboard, TrackPoint
Telecom
Modem Network / modem combo - CDC Max transfer rate 56 Kbps Protocols & Specifications ITU V.90
Networking
Networking Network adapter Networking / Wireless LAN Supported Yes Wireless NIC Atheros AR5002G Data link protocol Ethernet, Bluetooth, IEEE 802.11b, IEEE 802.11g, Fast Ethernet, Gigabit Ethernet Networking standards IEEE 802.11b, IEEE 802.11g
Expansion / Connectivity
Expansion Bays None Expansion Slots Total (Free) 1 ( 1 ) x Memory - SO DIMM 200-pin, 1 ( 1 ) x CardBus - Type I/II, 1 ( 1 ) x SD Memory Card Interfaces 1 x Display / video - VGA - 15 pin HD D-Sub (HD-15), 1 x Infrared - IrDA, 1 x Modem - Phone line - RJ-11, 1 x Audio - Line-out/headphones - Mini-phone stereo 3.5 mm, 1 x Network - Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45, 2 x Hi-Speed USB - 4 pin USB Type A, 1 x Microphone - Input - Mini-phone 3.5 mm, 1 x Docking / port replicator - 160 pin docking, 1 x PoweredUSB 2.0
Miscellaneous
Cables Included Modem cable Features Security Chip, Keyboard light, System password, Power-on password, Hard drive password, ThinkVantage Embedded Security Subsystem 2.0 Compliant Standards CB, CE, CUL, BSMI, CCIB, UL 1950, VCCI-II, Plug and Play, EPA Energy Star, FCC Class B certified
Power
Power device form factor External Voltage Required AC 120/230 V Power provided 56 Watt
Battery
Technology Lithium ion Installed Qty 1 / 1 (max) Battery capacity 4200 mAh Mfr estimated battery life 7.5 hour(s)
Operating System / Software
OS Provided Microsoft Windows XP Professional Software PC Doctor, Access IBM, Lotus Notes Client, Adobe Acrobat Reader, IBM Update Connector, Lotus SmartSuite Millennium, Norton AntiVirus 2004 (OEM), ThinkVantage Access Connections, ThinkVantage Rescue and Recovery with Rapid Restore
thanks all
General
System Type
Notebook
Built-in Devices
Embedded Security
Color
Black
Localization
Processor
Processor
Cache Memory
Type L2 cache
Cache size 1 MB
RAM
Installed Size
Technology
DDR SDRAM - 333 MHz
Storage Controller
Storage
Floppy Drive None
Hard Drive
40 GB - 4200 rpm
Card Reader
Display
Video
Audio
Input Device(s)
Telecom
Networking
Miscellaneous
Power
Battery
