Jerryl
Tall Unvaccinated Chinese Guy
- Dec 14, 2004
It's long winded, but hopefully you'll appreciate the journey . . .
I have been having some sporadic VERY LOUD exhaust backfire issues at WOT for about a year and would put $$$$ down on "visible underwear stains" of that Vette driver following the backfire in front of him, under the overpass.
The car gets driven an average of about 3-4 miles/week. So its takes a while to narrow things down, but this one was narrowed it down to spark related. I had already changed plugs, closed the gaps, added/verified grounds, verified system voltage, new Delco Ignition module/coil, RM plug wires, OEM Crank sensor, OEM cam sensor cap, yadi yada . . . . No dice.
Here is something interesting . . . . .
Two weekends ago, I started the car and the battery was bit weak . . . but it started . . . . then I got stranded around the corner of the house (3 turns) on the way to the local show. She would not re-start . . . pushed it home about 100 yards, and realized how out of shape I am.![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
The following day, it started up (Uhhh?) but only ran for 1 second and died. Thought the battery voltage dropped the previous day when starting, and set the anti-theft in some weird way that allowed it to idle, get me to the corner, and die . . . . Or maybe it is just trying to piss me off. Well I wasn’t . . .LOL. Back to . . . "it only runs for 1 second" . . . I proceed to reset the anti-theft in the chip and started her up, and she stayed running . . . Shut it off after about 10 seconds, hooked up the battery charger . . . try again next week.
Fast forward a week.
So this past weekend, she started right up and idled great. Backed it out, got her cleaned up, washed (sprinkled) the engine bay, pulled it back in to prepare for a visit to the local show . . . . . 3 hours later, cranked and started right up, backed it out, make 6 turns and got stranded again. (Uhh? . . We are making progress). No codes, SM numbers look good for no start/key on, Engine temp 140, FP is solid, No spark . . . . (Let's wait a bit for it to cool down, start it up, and go home?). . . . . Still nothing after 45 min. Sprayed crank sensor to chill it hoping it would start as to not have to tow/push again, no luck. (Hmmm . . Here is an idea . . let’s remove the P&P wiring from the T+ at the module as it may have gotten wet) . . . Removed it, connected the module to factory wire, and she started . . . and stayed running. (Yipeee!!!!) Drove to the car home, started right back up, and drive to the show . . . Stayed for 30 min . . . drove home. No issues.
Went home opened the T+, and saw some moisture on the inside cover. (No, I did not jet spray the engine bay, just misted it) Either way . . . I removed the P&P wire and tucked the ignition side of the T+ away.
We will see what happens next week, but I may be onto something! LOL
I know, only one way to tell if the backfire is resolved . . . but maybe the T+ was the cause of the backfires? Anyone seen this before?
(Yes, I will contact Bob B.)
