The Powerlogger will work with any chip. You can connect the wideband to the Powerlogger and log the air/fuel ratio with it. It doesn't matter what chip is in there.
However, if you want a chip that can look at the air/fuel ratio and make corrections to fuel at WOT on its own, then you would use the Wideband 6.1 chip.
Regards,
Eric
