Originally posted by Ted A.
You may pick up a little MPH with the 4 bolt now, but you'll give up something else.
I would not do the 4 bolt unless you have plans on really needing one in the future I.E. S2 stuff.
Originally posted by DR BOOST
s2 is in my future plans.
one of my main reasons, is to be able to use an ext wastegate on the crossover. i never liked the idea of rerouting high pressure bypass exhaust back into the downpipe. i was going to weld the racegate right onto the crossover and have it dump to the ground.
Originally posted by turbocliff
As far as going S2, if you know you will be going with an off-center motor, then you're headers will be the same, and you can spend the time and $ on switching the turbo set up if you'd like. But if you think you might go on center, then I'd wait until you are building your motor...
http://pg.photos.yahoo.com/ph/turbocliff/detail?.dir=2266&.dnm=2fec.jpg&.src=ph
Just don't weld up the cross over pipe under the car(under oil pan) and you will be able to use the same headers between off-center and on-center engines.
Surej, the first thing you should do is correct your drivers seat problem, and build up your right leg muscles so you can keep your foot on the gas when you release the trans brake....
