Will,
Get the 65 turbine wheel, which is the HP P Trim.
That is what I bought with the S Cover.
Waiting for Otto to come out and install it!
Don't think it will have enough snot for my goals. I would love to go with this turbo as it is different but I just wish they would go ahead and come out with a 67-68 compressor wheel.
Quite possibly Sun Will,I think this turbo will go mid 10s,But we are running it on a bone stock motor.Im thinking stock cam,ported heads and intake will make it a mid 10 car,but it will require 27 or so #s of boost but will the alky its not a problem on pump gas.
But my last car with the 6776 ported head cam motor want 10.80 at 127 on a easy pass with 22#s of boost,And hte DBB version spool real well with a 9.5 PTC convertor.
I would stay away from the 70 if your goal is mid 10s or so
My street car is a cream puff and will see much more street action than strip and will never have a cage. My goal is EASY mid-10s with a 5psi launch and reasonable boost levels - LOW 10s with a little more boost. The motor is a 235cid stock crank/rods, mildly ported GN1s, 214/214 roller with XFI. I don't want to lean on it too hard as the bottom end is nothing special other than steel caps. Patrick had mentioned the 70 with a .63 exhaust housing but I am afraid that would be somewhat choked off. If a dbb billet 6265 would get the job done, I would be all over it. I'll be curious how it works on your basically stock combo. After talking to Cal today about this very turbo, I think it would be good for maybe 10.40s on my combo but I'd have to run the snot out of it. I know the 6776 will get the job done but I just like the idea of running an out of the ordinary turbo.
