I have had a PL and SM 2.1 for a little while and love it.....I just wired up my PLX SM -AFR
I hooked up the 12v wire directly to an open pin on the fuse box. I ran a ground from the battery to the negative on the PLX (I also tied the ground from the analog to the same ground that is from the battery.
The one analog input I ran to the I1 pin out on the PL I/O bar
Now i dont have my laptop......i left it at the office.......
Since I can not look at the readings on the PL I thought I would just look at it on the SM which is what I intended.
The SM instructions on the display page does not show where you would read AFR's
The only reading I see that confuses me is the PL ( instructions say its the Pulse width reading) however the scan master display does not show PL it shows PU?????
So is there a setting I have to turn on through the PL to make the scan master read AFR's?
Is the PU readout on the scan master for the AFR's? if so why do the instructions say its for reading pulse width???????
I'm confused.....some help please
