well you didn't do it- you didn't do anything that was measurable scientific or formulated on paper that would add up to a accountant let alone an engineer.
i would like to know who your government contact is that told you it isn't being phased out along with the study on how much zddp was in oil in 87 and how much is in there now.
and
lets see your test analysis also (not richards on the excact amount of zddp) and names of oil manufacturers that gave you your info...
WHILE YOUR AT It ADD THE INDEPENDANT test labs you had it done at to ensure they were correct and the cost of doing so
scan them for proof
or
im calling bull**** to your empty attack/ rebuttal thingy
The CI-4, CIF-4 code says it meets the additive requirement for diesel and all flat tappet motors. FACT. The symbol itself is just a symbol. The codes are what matter, and the starburst has the codes that mean ZDDP is being phased out of that particular oil.
Yes, ZDDP is being phased out...but NOT out of ALL oils! And not out of all Rotella oil products.
I didnt HAVE to do a paper or study or report. Plenty of people already did that. Some oddball group called The Society of Automotive Engineers....SAE.
The test analysis, virgin and used, are all available on bobistheoilguy, if you look in the VOA posts. No misinformation in raw data. No opinions. Just test results. The fact I posted that the test results all are on that page, and you didnt look, shows you'd rather argue than read because you're lazy.
As for Rotella having the viscosity all out of whack...funny one. On the west coast here, we can run 30 weight year round. No one really knows that, but if you read the old buick manual, it shows a chart with what weights should be used for what temperatures. The range we have here, requires 30 weight. But 40 is fine, 10 is fine. Your motor will not seize up from running Rotella. I threw it in last month and it seems to be working just fine.
