eastwoodad
- May 23, 2003
Hey guys...I figured you all would be the best for this question. I have a block from a 84/85 T-Type and am using it in an application that will not require a turbo oil drain line.
My question is, on 84/85's where does the oil drain? Do I need to block anything off? I will be using a centrifugal supercharger that is self-containted (no oil supply/drain needed). I know on 86/87's there is a hole drilled and tapped on the front of the block but was unsure of the 84/85's. Thanks,
Aaron
Aaron
