TURBOPOWERED68
David
- Jan 31, 2006
shpping will cost you $550
good one
good info jason,and good thread to everyone whos throwing input to us....my car w/ta49,20+ psi ,stock cam....plenty of traction im going non-l/u.....not worried too much about mpg......
i need a 2800-3000 then? new valve springs,th dp,slic coming this winter.
got in the 12's with all stock engine,intercooler,stock air box,bad stock converter,bad valve springs... plus a ta49,tt chip...im bored now......
With the 10" converters you'd want a 2400. The stock cam needs a tight converter.
With my 9.5 you could run a 2800-3000. I can run these looser down low for spooling without giving up anything up top. The 10" converters can't do that.
I have been dreaming about a TC for a long time I just can't make up my mind.
HELP
TE-4461
Stock long block
3.08 Rear gears.
The problem is that I love my L/U D5 on the highway and stop-and-go driving, but my cow like off the line times and slow spool-up have me thinking about adding a couple hundred more RPMs.
200, 300 or 500 more?
What do you think?
Those 3.08 gears got something to do with that...
FWIW I have a friend (Gary its Barts Car) cars that just went through this as I did.
This is not a slam to Dusty or PTC, its simply a bud that didnt realize what we are covering here.
He bought a used PTC L/U 2800 10" and put in his car and it lays over in third doesnt accelerate.
He swapped the convertors because his other (12' 2800) was making noise.
The car has is .020 over, cam, valve job, TA49, etc and before from a 45 roll he would pass me. Now since he swapped convertors its literally like he hits the brakes and I run off and leave him.
Like I said nothing against PTC products. Just simply another example of what we are covering.
Hes going to pull it out and send it back to PTC for tightening.
Make sure to do a stall test at 0-1# of boost before taking it out. It's a huge help to have some sort of info to go off of when making changes.
Thanx for the info...
Ive heard 2-3 mpg loss with a no L/U is this true.
The others being more heat and possible cruise control surging if you live in hilly areas.
So for someone that drives their car daily and MPG is important I guess the best thing if one wants to stay with l/u and have good coupling up top is get the trans and a convertor that can handle the abuse and lock it at WOT?
Like I said nothing against PTC products. Just simply another example of what we are covering.gives
Might as well give an update on my TC status, its been several months.....
Was locking the convertor and shouldnt have been and broke every spring in the sucker and it was rattling like crazy and sounded like a POS.
I pulled teh trans and convertor and sent the TC back to Pats.
Steve at PAT's has stood behind this convertor above and beyond and put a new lining and restalled it and sent it back FREE!!
Knowing that it needed to be tightend I asked him to make the sucker around 2.4 -2.6k as efficient as possible.
He put a whole different stator and turbine design in it (the design used on the cars with DBB turbos) since my lil Gt3255 spools so fast.
The car is completely different now and is waaay better on the big end and all around for that matter.
Moral of the story...is staying with a L/U convertor and not locking it at WOT then get it as tight as you can get by with. Especially when dealing with smaller units.
So am I guessing that you stayed with a L/U, and chose not to lock at wot, to get the best of both worlds? I'm wondering, because I don't care about fuel efficiency with this car, but DO care about cruising rpms and the noise those rpm's make. So, under which WOT do you not lock it at? A full blown race wot, or both a race wot, and a 'just passing a slow car in traffic' wot as well. Exactly how hard is locking a l/u at WOT on our trans/converters? How did the stockers survive so long then?
I'm always investigating this, as I am at the crossroads as well. I too, would like the best of all the worlds. Low cruising rpms, low heat, good spool and decent mph ability...
