the grounds are that from the battery to the front of the block turbo bracket bolt make sure its clean of paint nice and tight get a battery post extender negitive side and measure from there to the chassie rail there's a hole there already you will also need to fine a bolt to bolt in then you know you will have a good chassie ground its not factory but should have been, and the other grounds from negitive cable to the fender go through them all make sure non of them are frail and are nice and clean and tight,then the one at the back of the block head .some people take that one and move it to the intake bolt from there it goes to firewall same thing take them out and go through strip any paint and make sure everything tight
