20psiofevil
- Feb 10, 2013
What is it when youre making boost at cruise?
Well here's my question... If it's making 3 to 5 lbs of boost at a steady 60 mph @ 2000 does the boost gauge drop to zero,when you take your foot of the gas? Just a suggestion..... I would change your gauge regardless,because knowing what your engine pulls for vacuum is just as important as boost. I would also inspect the intercooler,pipes etc. for any restrictions.Its always in boost the turbo make that wistling noise so i know its in boos!
Powerlog it, and look at the MAP reading vs the gauge??Me thinks the boost gauge is kaput. There's gotta be a way to test it, no? Something involving an air regulator and a compressor.
A poor flowing muffler doesn't add boost.I was cruising at lunch, I agree, maybe the muffler broke internally, could be a flow issue. Boost is just a measure of a restriction.
no it doesn't add boost but will make the engine create boost to keep the speed up as the muffler cant flow. May not be the case here but a restriction will cause boost as well as dragging brakes.A poor flowing muffler doesn't add boost.
Doesn't have to be rotted out, could be just coming apart inside, or the cat could be clogged if he has one. Car can be top notch but still have hidden problems. I also think the brakes could be doing it. But I would check the exhaust after I tried another gauge.The op has a nice car, its not likely for the car to have rotted out nasty clogged mufflers.
