Manual Boost Controller
Discussion in 'Turbos and turbo related parts' started by Stamos, Apr 4, 2017.
  1. Turbo Keith
    Turbo Keith
    Expand Collapse
    TURBO KEITH
    Sep 16, 2015
    725
    106
    Offline
    I guess its hard to go thru the fire wall , But I just installed a Hallman under my hood . Its set on 26 lbs and works great but I do get what dank GN is saying
  2. dank GN
    dank GN
    Expand Collapse
    always something
    Jan 11, 2009
    2,342
    180
    Offline
    Okay so that's the reason for mounting it under hood is the pluming . I understand that could be Alil intimidating having to run stuff through the firewall . Believe me I had my first BC under hood for the same reason. I thought after I plumed it inside that all the vacuum lines would cause some type of delay in the control of the gate . Much to my surprise it had 0 effect on the operation of it .
  3. Turbo Keith
    Turbo Keith
    Expand Collapse
    TURBO KEITH
    Sep 16, 2015
    725
    106
    Offline
    And I guess my thinking is the futher away means slower reaction time to spool . Which is probably wrong
  4. TurboTGuy
    TurboTGuy
    Expand Collapse
    Gray Beard Member
    Sep 24, 2010
    3,190
    820
    Offline
    In a closed system, Vacuum is Vacuum and Pressure is Pressure.
    • Like Like x 1
  5. Turbo Keith
    Turbo Keith
    Expand Collapse
    TURBO KEITH
    Sep 16, 2015
    725
    106
    Offline
    I just installed the one I got from you today , Works great . Its dead set on 26 LBS and hits there like a hammer .
  6. zapp240
    zapp240
    Expand Collapse
    Mar 17, 2016
    153
    32
    Offline
    thanks for that link V6sleeper, that boost controller was on my car when i bought it and could never find find who made it, i have tried a few others but have gone back to it as it works well.
  7. dank GN
    dank GN
    Expand Collapse
    always something
    Jan 11, 2009
    2,342
    180
    Offline
    I ran a MBC that I bought off eBay that was similar to rjc . And it performed the same if not better of all the other boost controller I have ran . I would say about 98% of the manual boost controllers function the same . They all have a spring and a ball . With something to apply tension to the spring After realizing this and being pissed for paying top dollar for muiltable MBC and just the name on them I switched to a electronic boost controller that actually has differences in the way the soft wear is programmed
  8. TurboTGuy
    TurboTGuy
    Expand Collapse
    Gray Beard Member
    Sep 24, 2010
    3,190
    820
    Offline
    Told ya........:D
    • Funny Funny x 1
  9. V6sleeper
    V6sleeper
    Expand Collapse
    T'chargd Wagon
    Jan 18, 2011
    1,296
    131
    Offline
    No prob (y)
  10. Omen340
    Omen340
    Expand Collapse
    Ex Buick Drag Racer
    Dec 12, 2015
    29
    9
    Offline
    Dark GN, I used it to tune the car for 21 psi boost and haven't touched it since. If I were constantly adjusting boost or wanted the ability to adjust on the fly I would definitely have mounted it inside the car.
    • Like Like x 1
  11. Stamos
    Stamos
    Expand Collapse
    Apr 7, 2014
    44
    10
    Offline
    Thanks for all the feedback gentlemen!
    I just ordered the Hallman RX kit to mount the controller inside the car.
    I'm going to put it somewhere inconspicuous. I don't like a cluttered looking interior personally.
  12. zapp240
    zapp240
    Expand Collapse
    Mar 17, 2016
    153
    32
    Offline
    that actually looks like a nice remote setup, let us know how it installs. might be worth trying one out. It says it uses a ceramic ball and lighter spring setup for finer adjustments and quicker response. but doesn't give a max boost capability with that spring. wondering if it will go between 25 and 30 PSI boost?
  13. Stamos
    Stamos
    Expand Collapse
    Apr 7, 2014
    44
    10
    Offline
    The rep said that the controller will work up to 25-30 psi. Once I'm back from vacation I'll get it installed and take some pics.
  14. fast86gn
    fast86gn
    Expand Collapse
    Texas Moderator
    Staff Member
    Sep 28, 2001
    2,856
    197
    Offline
    Here is my Hallman under the hood and dash.
  15. Stamos
    Stamos
    Expand Collapse
    Apr 7, 2014
    44
    10
    Offline
    Very nice! How has the Hallman treated you?
  16. fast86gn
    fast86gn
    Expand Collapse
    Texas Moderator
    Staff Member
    Sep 28, 2001
    2,856
    197
    Offline
    It's great I wouldn't change it for anything else. About 1 full turn is 1 lb of boost. Turned all the way out is 15lbs to all the way in at 30lbs.
    And moving it inside the car was the best thing I ever did.
    • Like Like x 1
  17. Stamos
    Stamos
    Expand Collapse
    Apr 7, 2014
    44
    10
    Offline
    Good deal, thanks for the quick reply!
  18. 87 grand
    87 grand
    Expand Collapse
    Ain't Life Grand........
    Jun 23, 2002
    131
    1
    Offline
    Can you tell me at what area of the firewall you push thru to inside of car ? That bc knob and mounting bracket is pretty big,
    #38 87 grand, May 16, 2017
  19. fast86gn
    fast86gn
    Expand Collapse
    Texas Moderator
    Staff Member
    Sep 28, 2001
    2,856
    197
    Offline
    Right by the steering shaft on the drivers side. It comes out right above the pedals under the dash.
    The cable can be started from the inside of the car.
  20. 1NASTYGN
    1NASTYGN
    Expand Collapse
    Oct 7, 2009
    341
    12
    Offline
    Can you use this with an external waste gate?
Share This Page
