If you do not mind, what size is the turbine wheel & the A/R of the turbine housing of your turbo?
Do you have a topic here with your build info on your Mustang or is it on a different forum?
Thank you.
Its a Precision T4 88. Its the smallest 88 they make. The housing a .96 ar and 4 inch outlet. Most of the 88's are T6.. like the X275 cars use. Those are way larger.
Dont know if I have a build info on it here. Basic run down on engine its a A4(4 bolt main) block, .040 over, JE off the shelf pistons, JE rings, Eagle crank and H beam rods, Holley Heads cleaned up, Victor Intake with Wilson elbow. Cam is a hydraulic roller from Cam Motion. Specs??? been 4 years.. its their largest hyd roller before going to solid roller. Double roller chain. Has Ford roller rockers, FMS(Ford Motorsport) graphite head gaskets, Block was o-ringed previously thats why the graphites. And they've been holding up. Maybe do some coppers on a future build. Balancer is a Proform.. Meziere electric water pump.
Transmission is a powerglide and has the 1.80 straight cut gears, JW bellhousing, and added clutch packs. Converter is a TCI ProXtreme. Rear end stock 8.8 with Moser axles and Eaton posi. 31 spline. Engine management is an XFI I took of my TTA. Runs TFI distributor(stock) and bank-bank.
My only fights have been boost control.. and that is getting handled. But aside from that.. no issues. Just plaqued by oil pan plug leaks(yes its the little things
One of the big helps is having 1/2 inch head bolts vs 7/16 stock. Like on a Buick. That seems to have helped keep the heads on. Tq on those was like 110 ft lbs.
Turbo kit hot side was from Pony Down. Was originally designed for a way smaller 76 turbo. The cold side was redone recently locally. Exhuast.. 4 inch DP reduced to 3.5 DP to a bullet muffler by the rear end.
