All parts NOT listed shipped will require shipping after cost calculated to your zip. Also, pay-pal account clusolynn@excite.com, include 3%, Thanks, John.
1. 85' actuator dual port $50 shipped
2. 85' TB with TPS/IAC/Vacuum block $50 shipped
3. 85' aluminum adapter from turbo to intake $20 shipped
4. 85' turbo exhaust housing and elbow from stock turbo $20 plus shipping
5. 85' Valve covers with breathers (will work on 87's) $30 shipped
6. Comp Cams Hyd cam with less than 6K $75 plus shipping 459 lift, will have to find cam card.
7. 980 springs with retainers and keepers $75 shipped
8. Hyd lifters (used with cam above, less than 6K miles) $25 plus shipping
9. Stock rocker arm assemblies complete $30 plus shipping
10. 43lb injectors with Commander chip (valet and security features) Note: stock long block with TE-44; these injectors and chip went 11.80 (there was also suspension work) $160 shipped for both.
11. Adjustable fuel pressure regulator (worked great) $30 shipped
12. I/C fan with a few scratches, still in useable shape with mounting bracket $35 shipped
13. Aftermarket boost controller (bought it off TB.com about 2 years for 85', bought 87' that came with RJC; never used) $30 shipped
14. B&M aluminum shifter cover $15 shipped
15. Known good D-5 convertor $50 PICK-UP ONLY! Lake City, Florida
16. B&M Street Stick shifter with 4 speed gate and all brackets to work with GM/Ford?chrysler; comes with own cover also. In new condition. $75 plus shipping
17. TE-44, mileage unknown (on car when bought) worked great last time run; upgrading NOTE: does have some play, does not appear to be touching. $350 plus shipping; does not come with actuator or RJC controller.
18. Straight aluminum 3 inch pipe used for intake 11 inches long $20 shipped
19. EGR/EVAP solenoid $10 shipped
20. G-80 Posi with drive shaft $600 YOU pull/ $800 I pull!
