Q QWIKWE4 Member Joined Aug 10, 2003 Sep 28, 2011 #1 Can this be done using the auxiliary inputs for the powerlogger? If so does anybody know where in the Alky Control system (which wire) to tap into too?
A aminga Chicks Dig the powerbulge Joined Dec 15, 2003 Sep 29, 2011 #2 Powerlogger takes 5V input. The voltage to the Pump is 12. And I believe that it's a pulse width modulated control. You CAN add a pressure gauge because what you're really looking for is the pump pressure
T TurboBob Resident mad scientist Staff member Joined May 24, 2001 Sep 29, 2011 #3 Monitoring/logging pressure is a much better idea. The voltage could be done, but you'd have to build up some circuitry...... Bob
