Other than the basics: balance rotating assym, line bore (with my steel caps)and bore of pistons what else is there? Just covering something I might of missed. I have not yet received the tear down report yet so I'm not sure if I need pistons or not or if the crank needs turned, if I do need (pistons) them I will go with a forged piston. I will be using 208/208 cam, new lifters, cam button and springs. Not sure if I will port and polish the heads at this time tring to stay to a budget. Fel pro gaskets all around including the head gaskets.
What would be the bearing of choice? Clevite or Federal Mogal?
I plan to introuce the GMHT articles to the machinist involved with this rebuild. So they can clean up the "poor spots" in the stock block. They are buick compotent fellows. TIA
