My Custom Engine & Car Build!
So I have had some delay. . .I purchased a xim coil on plug kit from Hartline Performance and the coil bracket lot that came with it will not clear the a/c. Back to the drawing board. . . . Need a better mounting solution
That is odd. Several have used it with AC. You may have to install just the lower rear bolt first and then swing the bracket into place
Tried it. There is no way it would fit even removed heat shield. No dice. I will take pics and upload tonight.
Looks like both need to be angled forward.
Fuel hose amd fitting (all black) this is ptfe hose. . No worries about fuel permientation. . No foul gas smell, E85 compatible and is conductive. . . Doesn't build static while fuel is running through it
Sam, where did you get the black ptfe hose?
thanks
simple solution. . Change angle. Now I just need to reinstall heat shield. . .It was a pain getting off. . .I'm regretting not thinking it out. Lol lesson learned......
I am glad to see you came up with a solution. It looks like I need to make another bracket for car with the AC, raised rail aluminum head (GN1), aftermarket cover combination. I'm sorry for the inconvenience.
No problem Cal. You guys have been great to me and like every build. . . Nothing is always ever directly bolt in. I'm eager to get you to help me with my tune and I predict you will probably be visiting me soon. Lol...
Ive been building my twin scroll headers. Started with driver side. . .m
been working on an exhaust pirt a nifgr since i work all day. Tomorrow i finish the driver side. .
Yes. When i bought the flange from ta performance they only had passeger side flanges so i just cut it to fit. The brace on the passenger side is to help support weight of turbo.
