Turbo6Smackdown
- Dec 31, 2005
Ok, with the advice of this board on going with a radial instead of a true slick, I purchased the 275/50 Hoosier drag radials and mounted them on 10" wide stock gn rims. While out for a mini test and tune this Sat. night I accidentally put the pedal down a little too deep as there was a built M3 that wanted to see if his shit was fast. As I showed him it wasn't, I actually started going sideways at about 60 feet out or so and had to get out of it. If everyone else is cuttin 1.7 or so short times with these tires, I'm starting to believe I have other technical suspension problems causing my total lack of traction.
Besides of what you see in my sig, everything else is factory stock. What should I be looking in to as far as improving my traction? Instant center? Trailing arm deflection? I'm lost.
