slimtastic
yea dude...I rock
- Aug 9, 2002
so i finally collected myself enough to make a pull or two with the buick and was supprised at what i got for a 15 lbs street tune on 93 octane
specs as follows
big stuff 3 tuned by me
stock heads
mildly built shortblock (i think)
218 cam (i think)
rjc plate
built 200r4 with 3200 stall
57 lbs injectors
ta-66 turbo/ which is wayy to big(i had it from a previous build and the orig turbo was smoking bad)
pte frontmount
372 hp and 384 torque with an unlocked converter
max hp was at 5400 and redline hardcut was at 5500...
15lbs, timing is at 21 degrees with a solid 11.2 afr to redline... any leaner and i loose power. interesting item to note is that im still building power to redline, but im not sure what i can safetly spin the motor to
i cant wait to see what 20 lbs will do, or what switching to e-85 and 1200 cc's will do!
specs as follows
stock heads
218 cam (i think)
rjc plate
57 lbs injectors
pte frontmount
