I am having serious trouble getting our '99 Park Ave Ultra to run at all. Car has 150k on the clock. It is running very rich when I can get it to start. It will idle with new plugs for a while then fouls them out and stalls. It sets no engine codes. The following has been tried:
1. compression is within 5 psi on all cylinders
2. new crank sensor
3. new coil module
4.fuel pressure is within spec
5. fuel pump module works fine in my son's '98 SSEI
6. all injector wires were checked with NOID tester and work to spec
7. relitivly new Delco plug wires (no more than 10k mi on them)
8. drained fuel tank and replace fuel filter.
9. gone thru the "no start" diagnostics in the factory manual with no conclusion
10.Swapped MAP sensor with a suspected good unit
I can swap sensors between the SSEI and the Ultra, not sure where to begin
Any help is appriciated.
2. new crank sensor
3. new coil module
