Does there have to be knock (detonation ) to push a head gasket?? Im just asking the question!! Suscribed Mike![]()
Nope. plenty of other things will do it also
Hey Bryan, Sorry to hear about your troubles.
Did RPE spec/recommend the Cometics?
Leaking coolant or combustion is different than blowing out the gasket. There can surly be a few different thing that can effect sealing.
IMO If the surfaces are trued and heads are properly torqued, you would be hard pressed to blow out a cometic. You may even blow the piston before the hg. Those gaskets are tough. The problem is they do not seal well.
I know a guy who glued on his cometics with the stuff RJC uses on their gaskets. Maybe he is ahead the pack here.
It doesn't matter how good a gasket seals. Once the head lifts up and the combustion gases find the path of least resistance, game over. I think phoneguys car is proof...if rpe sealed it up..its done right...period.
I believe all these blown head gaskets are from detonation from being lean because of a lack of alcohol in that cylinder. I would really like to see these cars run without the alcohol with a race gas tune and pushed hard to prove this point. We are going to do it with the car I'm involved with. My own car will be spraying the smallest amount I can just for the cooling properties when I get it together this winter. It will have the same combo all thhese cars have except my dfi instead of xfi. If you think of it, these cars are sequential fuel injected ....a pretty precise means of fuel delivery. The alcohol being sprayed in has no precise control. Most serious fuel injected nitrous cars I've seen have direct port systems on the intakes. I would feel this would be the best way to inject the alcohol. This is all just my theory.
Your may be right Kev, that would explain #1 and #2 going lean.
Maybe it's time to bring a direct port system to the market.
Julio? I know your watching.WDYT?
Just throwing my 2 cents in...From what Julio has said (no personal testing) the alky basically vaporizes as soon as it hits the warm air in the pipe...If that's the case I would think that it will go to each cylinder however evenly the air is flowing.
I would personally be looking in another direction for the problem.
JMO no cold hard facts to back it up.
nope. Plenty of other things will do it also
Not sure how that could be tested. I wonder if there is too much alchy, the alchy has problems vaporizing. Seems like some cars run great with no issues and some have a bunch of problems. Yours and Roberts car definitely have the combo working...thats for sure. I can't wait until next year when my car hits the track again with my alcky control system on it. Plan on going to the track a lot and hopefully learn a thing or two...hopefully not from breaking sh!t though lol.
You dont always have detonation when you melt an engine. Ive datalogged detonation on XFI when leaning a cylinder. If you making any power an detoante a little forget it. Its toast.
