new shortblock in crate
109 block
eagle h-beam rods
eagle forged crank
arp rod bolts
arp main studs
t/a billet main caps
cometic .040 head gaskets
je pistons .030 over
je rings
clevite bearings
internally balanced
new harmonic balancer sfi approved
new flywheel sfi approved
champion cast iron ported heads assembled
ta performance 270 cam-270 duration .455 lift (already degreed in)
t/a performance lifters ta performance blueprinted oil pump assembly.
everything listed is new
motor has warranty
was built by golen engines
7000.00 for all
if i am forgetting something i will add it later.
109 block
eagle h-beam rods
eagle forged crank
arp rod bolts
arp main studs
je rings
clevite bearings
internally balanced
motor has warranty
7000.00 for all
