Can anyone toss some advice over my way or maybe proper instructions on how to replace this the proper way(I can turn a wrench pretty much) I want to do this one time and never want to think about it again. Any help or input is greatly appreciated
Seriously...it's not GM...wooooow. Well I have no more cash and if I did, I certainly would try to avoid this money-sucking machine. I have to use my recourse for this one.. I'm a lucky one
Inspect the pocket the gears ride in, THATS the important part. You didnt show that picture.
Actually I meant to open it up and look at the condition to see if it's scrap metal. With a used cover you never know if any (or how much) debris has went through the pump and scored it up.
....the one you pictured doesn't even need to be opened up to know it's sub standard. The above pictured unit is a chinese copy of a GM cover. Personally I would run a genuine GM cover that I found at the bottom of a lake before I would even consider running a brand new chinese unit.
The spur gears sit in machined pockets. One drives, one is driven.You will see them when you take the pump apart. Side clearance between the spur gears and the housing, plus the clearance of the cover, usually controlled by the thickness of the gasket, (most are too thick) determine how well the pump will function.
Jay J
The manual is available for the entire engine. Clearance specs are there.
where is this manual
