BGNeXtreem
- Apr 20, 2012
Rjc is the only place I know of that has the gasket with out all the dimple holes
TA Performance has almost the same pan gasket.
wmerrell said:Heard back from Weber, they are blaming the irregularities in the RJC oil pan.
Oh, so I guess they didn't check it before they put it on. Wonder what else they didn't check? Oh well...you'll find out.Heard back from Weber, they are blaming the irregularities in the RJC oil pan.
One thing I've learned over the 11 years of TB ownership is the second you put anything other than a stock part on you better check everything. Sometimes you get lucky, most of the time something needs massaging. Even with the best intentions, sheet happens.None of this stuff just bolts on.
I really did not want to spend ten grand on an engine.
Weber built me a new "crate" engine.
New block, rotating assembly, oil pan, cam etc.
The only items from the old engine were the heads that Weber rebuilt and intake.
Silly me thought Weber would be able to produce a great product.
