Hi,
So I got my S2 engine and trying to figure out parts an tolerances.
1) Cam - specs unknown, markings: Precision Turbo & Engine Z-2460 BV6-224-1210.
I tried to contact Precision from the online form but no reply.
2) Sleeve - the block has a crack in #1 cyl. I have a local machine shop, but they don't have a sleeve itself. Where could I purchase one? 4.010 bore.(016 block)
3) main bearings. The crank is 0.010 under already, but the #2 main needs a 0.020. Can I only grind one main bearing neck and buy two sets of bearings?
Problem is not cost, I just want to leave meat to the others and since this will be a racing app, it will need a regrind every now-and-then an if I grind all of them all the time, I will need a new crank too soon.
Thanks in advance.
P.S. taking it to one of the good builders is not an option, I'm 3000 miles over a pond
Thanks in advance.
