Hello,. I just installed my old power logger, plx wideband & new SD2 CHIP and scan master G into another GN.
The computer in this car has a wire hard wired into it that plugs into an AEM 5 bar map sensor.
I have Comms wire from the SM G connected to terminal 7 labeled SM on my power logger,
The grey wire from my plx to terminal#1 on power logger
What terminal do i connect the aldl to ob the PL?
The instructions from the SM G says connect comm to the Aldl but seems like i remember when running a power logger you disconnect the wire from the aldl and connect it to the power logger but I am not sure.
The instructions from the SD2 chip says connect I2 to the map but remember my map is hard wired.
The Scan Master powers up and says connected but it is not showing any data
