pull the turbo oil feed tubing off and see if you can blow through it
your first post stated you had "good oil pressure" , if thats true your readings should be coming from the bras tee ..so i dont understand your second post that you were "puttins oil pressur gauge line to brass t".. ???
maybe its too early to expect posts to make sense .. but where were you getting your good oil pressure reading from ??
