oil drain tube gasket?
daturbosix
where can i get one locally?
apparently felpro includes it in a "turbo kit" but i just need the oil return gasket..
are these drain gaskets the same as something else?
When I was trying to get one local I could only find it in the felpro turbo kit. I ended up ordering a few from a vendor so I always have at least one or two on hand.
Check the dealer or your local turbo shop or "tuner" shop. Worth a shot. Where are you located. I have a few.
aaron
get out a hole punch and some fiber gasket material. Should do the job well enough.
I usually have a few on hand. I get them from RJC.
If you end up needing one I'm in the south subs..
Rick
Almost all the vendors carry them. They are made from an oil and heat resistant material.
Always a good idea to keep one on hand.
