sorry to drag up thread again but i have a couple ?'s
1.kyturbo's cage install pics,when u weld tubes to the frame through the floor,do u guys also weld the tube to the floor or do u leave room between the pipe and the floor.i would think u would want some space there so the body can still flex and not make noise as it is rubbing.
2.if pipe is not welded to floor what do u put in the gap,dumdum?silicone?seam sealer?etc...
3.if u install 6pt bar and install kickers that go through the rear shelf to the trunk,where do u guys like to weld the ends of kickers too,the top of the spring seat on frame?
4.this one maybe a dumb one but,do u guys just put car on level surface and install cage ,is there any way to check if frame is not tweaked(like x'ing the frame to make sure its not diamonded)before u weld tweakness in for good?
5.which is lighter mild steel or chrome-Molly?i am assuming chromemoly is stronger.is it harder to work with?cut,bend,weld?can it be mig welded or does it have to be tig welded?damn newbie's
