T Turbo Keith TURBO KEITH Joined Sep 16, 2015 Dec 14, 2018 #1 I'm running a PL and a 2.2 Chip in the Scan Master , How do I wire it up so the PL will read Boost ? Thanks in advance Keith
T TURBOPOWERED68 David Joined Jan 31, 2006 Dec 14, 2018 #2 Signal from the map gets hooked up to the PL inputs Then the PL and scanmaster get configured to show boost on both ends
T Turbo Keith TURBO KEITH Joined Sep 16, 2015 Dec 14, 2018 #3 TURBOPOWERED68 said: Signal from the map gets hooked up to the PL inputs Then the PL and scanmaster get configured to show boost on both ends Click to expand... Can you show me hows that's done ? Or where its connected ?
TurboTGuy Gray Beard Member TurboBuick.Com Supporter! Joined Sep 24, 2010 Dec 14, 2018 #4 You're running a 3 bar MAP, I assume? https://turbobuick.com/threads/powerlogger-and-gauges.340795/#post-2711983
T TURBOPOWERED68 David Joined Jan 31, 2006 Dec 14, 2018 #5 Turbo Keith said: Can you show me hows that's done ? Or where its connected ? Click to expand... TurboTGuy said: You're running a 3 bar MAP, I assume? https://turbobuick.com/threads/powerlogger-and-gauges.340795/#post-2711983 Click to expand... What he said
T Turbo Keith TURBO KEITH Joined Sep 16, 2015 Dec 14, 2018 #6 TurboTGuy said: You're running a 3 bar MAP, I assume? https://turbobuick.com/threads/powerlogger-and-gauges.340795/#post-2711983 Click to expand... Yupper
T Turbo Keith TURBO KEITH Joined Sep 16, 2015 Dec 14, 2018 #7 I just read the thread , Thank you Guys
T Turbo Keith TURBO KEITH Joined Sep 16, 2015 Dec 14, 2018 #8 This is the green wire I just splice into and run it to the 12 port ? Correct Sirs ?
S ScottHeidinger Active Member Joined May 2, 2015 Dec 15, 2018 #9 Yes Sent from my iPhone using Tapatalk
TurboTGuy Gray Beard Member TurboBuick.Com Supporter! Joined Sep 24, 2010 Dec 15, 2018 #10 That's the one.
TurboTGuy Gray Beard Member TurboBuick.Com Supporter! Joined Sep 24, 2010 Dec 15, 2018 #12 It's amazing how these little cars can humble just about anyone..... In so many ways........
