- Nov 30, 2009
You may be right. I need to check for vacuum leaks also. My hoses are old. You know a good place to get the intercooler hoses? Know the vacuum hose sizes? I'm going to install my walbro fuel pump and remove my cat. Don't need emissions. So I can just weld in a piece of straight pipe correct?
You can gut the cat , it's just a ceramic honeycomb material that is pretty brittle . I gutted mine back in 87 with a wood spade bit on a 16" extension and just shook out the pieces ( remove it first )
