I'll look at that log when I get home to see if its all too familiar. I don't have my laptop with me. I could have had 100 logs by now but I quit because they all are the same.Log from July
ok, thanks!I'll look at that log when I get home to see if its all too familiar. I don't have my laptop with me. I could have had 100 logs by now but I quit because they all are the same.
ooof.... autolite 133's, which is a non-resistor plug. In general, non-resistor plugs are a no-no for computer controlled cars. Lots of RFI from those. I would put that on the list of things to try out (change to a resistor plug).
I know people have successfully run those, but it's something to try anyway.
Log from July
Yes tried with no laptop. Same issues. I really have a very good suspicion that Eric is right about the plugs. I am unfamiliar when it comes to non-projected tip plugs or pretty much anything non-OE. Until I put these plugs in I had never even seen a non-projected tip plug. I had no idea they were non-resistor. My ignorance.ok. I just read through all this and didn't see one thing: I assume you have a laptop connected and running while all this is going on. if so, have you tried it without your laptop connected? possibly something in your laptop causing this??? I love how some people's first fix is to throw a 500-2000$ part at something to fix it. I had Dale Cherry tell me years ago " recommend old 25 year old computer technology be replaced with XFI " 2500$ PLUS dyno time! The problem ended up being engine mechanical issues!
I have not seen his log yet, but judging by your response it probably looks just like mine. I guarantee you with all due respect all those suggestions are not the issue with my car at least. I have physically checked all connections. Measured while messing with harnesses, and performed loaded voltage drop tests on ECM power circuits with a headlight test fixture as well as chassis grounds, etc with a carbon pile load tester. Not to mention measuring power and ground in a high refresh mode (0.000250 seconds) and seen no issues. The only one I have not finished testing is the 12V switched ignWhen the volts drop to 0 it would appear something going on with main power.
A few things that come to mind:
Loose battery cables
Bad hardware on battery
Bad positive cable
Positive cable hitting header when engine torques from power
Rick
Bad positive cable
Rick
Just saw this ...I am running AR 133's, whats the recommend resistor plug equivalent?
frames where everything goes to 0 (including the ignition volts) is the ecm rebooting. When the ecm reboots, it clears its internal memory, the PowerLogger is reading the ECM memory to gather its data.
its not going to be the voltage feed to the ecm.
Anyone with this issue in Michigan......?
Bob
Just reviewed your log and it is EXACTLY my problem. Notice how TPS, BAT Voltage, MAF, etc all drop to OV in frame 500 followed by engine RPM dropping to 0 a frame later? This is my exact issue to the T (plus or minus a frame time wise)Log from July
No I live in DE. But if I'm not the only one having this issue and we can't figure it out I'll be a team player and drive all night to your location to spend the day with you. I'll even buy you lunch and / or dinnerframes where everything goes to 0 (including the ignition volts) is the ecm rebooting. When the ecm reboots, it clears its internal memory, the PowerLogger is reading the ECM memory to gather its data.
Bob
