Under Pressure
- Feb 8, 2004
Anyone have any info on walbro's take on this?I tried to contact Mike at FTS to see if he had any info ,but no reply yet....
Will full throttle do anything for us?
It now appears that I'm another victim of the Walbro pump saga. After a 3hr run to Charlotte (Lowes Motor Speedway--Auto Fair) Sat a.m., my car/pump died (in traffic on Speedway Blvd non-the less!). After 5-10 min (3 traffic- light-changes & lots of pissed-off fellow "car enthusiasts" later) cooldown, pump/car finally restarted & I was able to get car into Speedway/ & parked w/ Southeast GM Turbo 6 Group Display. I was then OK for several more trips--about 30 minutes or less each--4-5 hours later that afternoon. Didn't move car on Sunday.
Today, Monday, returning from Charlotte to Myr Bch--car craps out again after 2hrs & then 6-more times in remaining 1-hr to get home. Last 3 crap-outs, car/pump would only run about one minute after a 3-5 minute cooldown. Seems like it is a cumulative heat buildup problem.
After finally home in driveway (coasted-in w/o pwr strg or brakes ) I tested 3 more times, w/ FP gauge laying on windshield: FPmp would not come on w/ ign sw until 3-4 min cooldown from prev stall, & then FP & engine would would start-up OK & idle about 1-2 min before FPres would start droping, FPmp would soon stop running & engine stall-out prontito...
My remaining question is whether a bad FPmp relay could create problems like this--cause this to happen??
[For the record, my pump/kit (834GMHP) & Hotwire Harness, purch from Mike/FTS also, was installed about 2-years ago.]
Exact problem I had.
The inlet is the problem? OK I,ve heard it all now.
I know right...... were my thoughts too when I received this info....Not to say that is or isn't the problem, I'm no expert on fuel pumps and I don't know much about how they work or how it all comes together, but my common sense thinks how the heck could an inlet cause all of these failures??? and the real question is it just limited to the F20000169s or is it happening with the 340s too? cause if it's happening with the 340s and the others they make than the issue is beyond the inlet. I've apparently never had an actual 340 eventhough I thought I have all this time since they all have F20000169 stamped on them. To my knowledge and what others have told me the internals of the ...169 are the same as the 340 and I assume the only difference between the two is the inlet. Dunno for sure though since it hasn't been confirmed to me by the manufacturer.
and just keep using my TTA/Syclone Pump.
