about an inch from inside the rail about 2.5" back from the large hole toward the axle
what i do is drill a 3/8 hole , reach through the large hole and drop a bolt with a lock washer on it through the hole and then put a nut on and zip it up
now you have a stud to slide the bushing onto , then a flat washer and a nylon lock nut
