The "manual" states that:
The batch fire spark and fuel ECU incorporates a series of 4 internal peak and hold 4/ 1 drivers and has the ability to run 8 low impedance injectors at full duty cycle for short periods of time.
I'm slightly confused...so if I'm running this on a 4 cylinder (4 injectors)...how does this affect it? Can I then safely run low impedance injectors all the time?
It says it has 4 peak/hold drivers...and then it says it can run 8 of them for short periods of times...
Also, if it has 4 peak/hold drivers...what do I need to run high impedance injectors?
Thanks in advance!
Thanks in advance!
