Adam Whitman
- Jun 10, 2001
I did that search too, and other than all of the photos from kit sellers, I found the same TB.com thread and this:
That video is useless. It has no details whatsoever about the valve body. But I did watch it last night. it has a nice burnout for a commercial video.
YAY!!! Thank you to both of you guys for your efforts, and the assistance!
Boy, Dave is once again right. I have the NoYoYo kit installed that uses the tension-spring "spacer" described here: http://turbobuick.com/threads/weird-spring-and-kudos-to-david-husek.449130/#post-3740214 while not described in these instructions.Those directions are one of who knows how many different versions of the kit. You have to tear the VB apart and remove the bad parts of the kit.
If you want the valvebody returned to bone stock specs--send it to me and I will take it to Richard Clarks and do the deed. RC has all the stock springs reproduced. Once it's corrected you can do a few simple mods to it(or I can do it when I have it ). Contact info in my sig if interested.Boy, Dave is once again right. I have the NoYoYo kit installed that uses the tension-spring "spacer" described here: http://turbobuick.com/threads/weird-spring-and-kudos-to-david-husek.449130/#post-3740214 while not described in these instructions.
Also found a broken "red spring" from the NoYoYo kit for the 2-3 throttle valve spring.
My valve body doesn't have the Line Bias Valve spring corresponding to these instructions, or the stock colored "chrome-yellow" spring.
One valve has a flat on it that may/may not be stock, but it doesn't appear the valve body is butchered by at least any obviously drilled non-stock holes or plugs to my untrained-but-learning observation.
And finally, having these instructions was still a huge help as it aided in comparing the stock config shown in gnttype.org, the NoYoYo, and what I have. Finally, why is the valve setup included in the gnttype diagram including #307 blacked over? I think mine has this, but is definitely a BR3 valve body.
Adam, I can not answer that those Richard Clark's and he's invested 1000's into reproducing all of them. He may not sell them, but he will service your valvebody.Thank you Steve. Dave was of your same thinking along with an inspection to ensure it didn't get any holes drilled or plugged as part of some of the TransGo kits. I think I'm going to peruse the instructions of the NoYoYo kit I ordered for the red spring and decide then whether or not to stick it back together to see what happens since I now have the valves un-stuck and have done searches to review what just about every spring for every valve does and compared what I have to the measurements of the stock springs. I think I've got the reassembly handled with the possible exception of a valve having a flat ground on it nut being stock and causing problems. And stock calibration might not be exactly right since it's going behind a V8 in a 3200 lb car anyway.
With that in mind, I should ask, and should have asked Dave before ordering another TransGo kit, how much would it cost for me to buy a set of stock springs?
OK, thank you, Steve. First, I am going to try Gil Younger and $32.95Adam, I can not answer that those Richard Clark's and he's invested 1000's into reproducing all of them. He may not sell them, but he will service your valvebody.
