TURBOPOWERED68
David
- Jan 31, 2006
no cons
Not to get off topic but noticed your pcv breather. How do you like it like that? I run mine open air too thru a tube and it works great. Like that though too!View attachment 301041 View attachment 301043 View attachment 301042
My budget version. I gotta get that paint run sanded out !!!
I though about tapping that egr cover for 2 screws as well. Do you happen to remember what size you managed to fit in there?View attachment 301041 View attachment 301043 View attachment 301042
Sent from my SM-N900P using Tapatalk
Got it, thanksI used 10-32 screws. Need to be short or cut off. Only tapped about 1/4 " to 3/8 " deep. My cover is cosmetic shimstock only. The ports are plugged with pipe plugs underneath.
Nice setup does the coil and mount clear the line? What fittings do you have between rail and reg? Doing same thing with Cruz performance rails thank mike
If your running Cruz rails you may as well get his coil bracket too. It leaves more room under the coil than the stock mount. Very nice piece.Nice setup does the coil and mount clear the line? What fittings do you have between rail and reg? Doing same thing with Cruz performance rails thank mike
I have a Precision SLIC, no plenum spacer and the up pipe still rubs slightly on the hood liner.
Stock, GN1 ported intake manifold and stock ported plenum.I'm assuming since you didn't specify, you're running a stock plenum and not a raised plenum such as a Precision unit.
I've thought about it but the slight rub doesn't bother me. The only way I knew it was rubbing is the top of the up pipe is slightly polished. I've seen this tell on lots of GN's.Same issue here for me and same Precision SLIC.
I've got a couple of suggestions:
1) Have you cut off a small amount of material on the bottom of your up pipe (where it connects to the intercooler)? You can reduce the angle of your up pipe a smidgeon this way. Just gotta find a shop to put a bead roll back on!
2) Another alternative is install an offset 3" x 2.5" Silicone Reducer Cplg connecting top of up pipe to throttle body. This will lower the up pipe's height by 1/2".
3) Last resort is remove the 3" up pipe and install a 2.5" up pipe to gain an additonal 1/4" clearance.
