Out with the old
In with the new
OK, I have installed the new parts, and all things considering, it went better then planned. It was getting a late in the day when I got everything connected so I didn't have much time to mess around with the FPR but it seems like it wasn't adjusting at all. The fuel pressure stayed at 38# line off and when I tweaked the screw, it didn't change anything. Is the screw fairly sensitive, or do you really have to make a lot of turns to see a change?
I didn't unplug the injector harness. What's the point of that?
Great advice from everyone here. Please let me stress how important it is start the fuel return line threads FIRST before bolting to the fuel rail. I stripped mine and has to replace fuel line. Not fun and waste of money for line.
Good luck!
So you lube the O-rings before you remove the injectors? How do you that? I think I sprayed WD-40 or something on mine, then pryed them out with a spoon. I didn't unplug the injector harness. What's the point of that? By the looks of it, I would probably wind up cracking that white connector.
Are those little clips at the top of the injector that go over the fuel rail and the injector housing needed? I broke one today. I only ask as they are not on one of my other cars when I did a swap.
If they are needed, who is the vendor to go to to get new ones, thanks!
That may be a temp switch you are referring to. Pinch it across the "fat" side, and pull up.Looks like I may have to remove it to get my fuel rail off. First, can someone tell me what it is? and Second, how do I remove it?
There's a black, plastic round object, looks to be connected to the intake, it is just to the right of hte fuel pressure regulator. Looks like I may have to remove it to get my fuel rail off. First, can someone tell me what it is? and Second, how do I remove it?
Thanks,
Joel
Yes easy job turn into a couple days . Do one thing at a time.Great advice from everyone here. Please let me stress how important it is start the fuel return line threads FIRST before bolting to the fuel rail. I stripped mine and has to replace fuel line. Not fun and waste of money for line.
Good luck!
