Kaine Beedenbender
- Jul 14, 2013
Love the pics and the progress, very nice to see people putting the effort into restores.
Looks good! Is your alternator brkt powder coated or painted? You need to get down to the metal surface or you will not get a good ground. I put external tooth washers under all of mine also. Just a thought.keep the pictures and info coming your doing great. See ya! John
I just made downpipe yesterday. Cost $200 in materialBrad_H is that the GBODY downpipe? Thought that pipe was backordered? Looks a little different though. Car looking good![]()
Thanks manWay to go Brad, it came out almost identical to gbodys pipe
It's a two pice that joins at the bottom just inline with firewall so it's still easy to install and remove. It's not done yet just have to weld on the v bands to connect it but it clears really good ill post pics in a fewDAMN Good work. You happen to have any pictures of the down pipe build. Is this a two piece unit? Did you use mild steel or stainless. This is turning out to be a GREAT Build.
