Not a problem..... Good luck. Though FYI, the reason for the powder coat is that gold looking paint on the inside and out flakes off getting into your oil and making the outside of the pan wear faster and make it look beat-up looking. And I'm sure that stuff flaking off in your oil isn't good for your motor. Hence the reason I had mine "bead" blasted (not sand blasted) and coated.
