Originally posted by MR.BLONDE
I need to know what I will need to do (motor/turbo/tranny/rearend/ECU) to run mid to low 12's reliably (daily driver)?
Any help is greatly appreciated.
Motor - Stock, no mods necessary
Turbo - Stock with porting of the turbo elbow and manufacture of an adjustable wastegate (about $4 if you do it yourself)
Tranny-Stock, but its a good idea to have it serviced and adjusted by a professional and have a shift improver kit installed.
Rearend-Stock with right side airbag in the spring, simple brake mods for higher boost launch (S10 pickup wheel cylinders, 4 long shoes)
ECU-Adjustable fuel pressure regulator will help with tuning.
Other things needed:
Good fuel pump like a Walbro 340
Scan tool like Turbolink, direct scan, or a scanmaster
Boost gage
A free flowing exhaust or a dump
K&N cone airfilter or equivalent
Sticky tires like drag radials
a good race chip like a Thrasher 108 with TCC lockup
Race gas or a race gas mix.
With the above you are pretty much guaranteed mid to low 12's once the car is tuned out (assuming the car is a factory positraction car) Don't worry too much about race gas...it goes a long ways if you are like me and pump it out after running at the track. Not having the ability to run 118 mph everyday on the street is why I still have a drivers license.
Check my signature for a timeline of performance achieved vs. mods done starting with a relatively stock (slower than stock, actually) car .
