SOLD!!!!! Belltech 2102 Drop Spindles
vader87
Protected Freedom for 27 years! Thank a Veteran!
SOLD!!!!!!
Brand New, ZERO miles. Purchased for use but ending up going to coil overs.
These spindles are used in conjunction with the 1998-2005 Blazer Front brake upgrade. These ARE NOT for the factory style TB seTUP.
By relocating the wheel mounting point a.k.a. spindle pin higher on the spindle casting, our engineers were able to provide a 2-3" lowering without affecting any other suspension or steering geometry, not even the shock absorber
  • Belltech Drop Spindles offer a 2 or 3 inch drop depending on the application
  • While improving handling and retaining factory ride quality; Belltech spindles maintain critical suspension geometry and eliminate excessive ball joint, shock and tire wear common to other methods of lowering
  • Each spindle is built from OEM grade high strength ductile iron, providing the structural integrity to meet and exceed all factory specifications & requirements
  • OEM ride quality with added performance, control and comfort
