GNBRETT
Pelennor Fields
- Feb 8, 2004
You are motivating me.
A couple of quick questions...
1. Are you putting the external wastegate off the header? Just wondering what the setup looks like if you do, to compare to mine.
2. Are you putting an inline accufab regulator on the champion fuel rail? My setup didn't seem to like it so I converted to an external regulator. Seems like a few have run into issues with that setup on fast cars.
The area where the frame was notched and welded is actually much thicker and stronger then that thin piece of metal from the factory. If you go back and look at the pics you will see that an 1/8 inch of solid steel was welded in place. Look at the last pics to see how thin the metal from the factory frame is and the fact that it is hollow in between.Brett, how thick is your frame where it was notched and welded? It doesn't appear to be very thick, which led me to the question of how strong that area really needs to be and what forces are acting on the frame in that area.
If you hooked and lifted the wheels, would all (most) the lifting forces be generated where the 4 rear control arms mount? thus the reinforcing you did in this area...
From the rear axle back, i might guess that the frame is really only holding up the trunk?
Do you have any pics of the car with the tubs installed and the interior installed? can you notice the tub at all in the back seat?
Thanks,
Nate
Brett that car has Cargo coil springs in the back
Actually the kind that Brett likes,yes they would be!Are those needed when hauling a$$?
Yea, im switching them. Thanx BrickBrett that car has Cargo coil springs in the back
whats wrong with the cargo style springs?
Yea, the sleeper effect might be tough to pull off but the tires are stuffed under there pretty well so at night it will look fairly calm. Definately NO bar of any sort ever! I'm sure many have said that....Looking good Brett but think I would have gone for a roll bar while everything is apart. Car is never going to pass for a sleeper anyway!
Few pics of interior put back in place after the mini-tub as well as the carpeted trunk with spare tire....
