Dave_Harris
- Oct 25, 2011
Givin the following setup -
Bailey's 2-Step set to 2600 rpm
Stage right tranny brakeAny
PTC 2800 stall
Fast XFI engine management
What's going to spool up the turbo faster:
retarded timing / rich mixture
retarded timing / lean mixture
advanced timing / rich mixture
advanced timing / lean mixture
Looking for consistant boost level in a short amount of time (from the time I stage till the time the go light comes on). The time frame can be as short as 3 seconds, and as long as 10 seconds or more. My current setting is a slightly lean condition (13:1) with the 2 step pulling out 8 degrees of timing. This allows a launch boost level of 7 psi after a short 4 sec stage, but if I'm in the beams for longer the boost level rises to 9 or 10 psi.
I'm trying to find a way to stage, go WOT on the 2 step, and build a consistant level of boost no matter how long I'm on the box, whether its 3 secs or 10 secs.
Any suggestions welcome
PTC 2800 stall
