Were did you buy the oil pump kit and what did it cost
wow....clean...i like...
Sweet!!!!!!!!! Very nice Allan, few questions;
Are those ATR headers modified to change the turbo location or are they custom made?
What are you using for fuel lines -8 feed and -6 return? or -10 and -8?
prasad
They look like modified ATRs... I know someone who needs to make the same modifications over the winer, and I like how Allans turbo sits.
prasad
Headers are modified ATR's. Added RJC 1/2" flange to passenger side header. There is a tubular turbo mount supporting the turbo on the bottom.
Fuel lines are -10 supply, -8 return
Allan G.
Thanks for the quick reply Allan, did you add the 1/2" RJC flange for better seal for the headers or to make easier to get to the spark plugs? or both?
Was the spacer welded all the way around the outer edge as well as the inside where it meets the ports?
Prasad
Fans worked out great! Never thought about using them as pushers. Concerned that the shroud might restrict the air flow thru the radiator though being used on the front of it. You have enough room for the intercooler????
