I'd love to see some pics of your engine, what is your combo?
Mike
Ok here it goes-
-RPE built 4.1 off center stage 1 long block done through Cotton's Performance
-Champion heads with everything
-Champion ported BGC Intake
-Sheet metal plenum done by me
-Mezzier water pump
-90mm throttle body
-Razor Alcohol injection-(two nozzles)
-lots and lots of custom fabricated stuff all done by me
-Big ass intercooler built by Jack Cotton on my specs
-Twin Turbonetics 60's ball bearing Turbos
-Tial 44mm twin wastegates
-XFI 2.05
-reverse pattern th400 with transbrake built by Loni
-Aeromotive pump and regulator
-160lb injectors
-EGT probes in all prmaries
The list could go on for ever!!!!!
So much planning went into this set up. I wanted a motor that was easy to work on and super reliable and beautiful. It had to drive on the street to the track and to car shows. So far, so good.
I was told that you can't build something like this and just drop it into a mostly stock car. And this is so true. So, at first, I focused completely on the motor. Upgrading the rest of the car came as needs and funding allowed.
Now it's almost done. I would like to do something with the suspension, wheel and tire set-up for street use. Maybe not because it's driven to the track and raced as it was driven. Still thinking on that.
